Low idleling high vibration...
azpunkguy
08-21-2006, 08:57 PM
:banghead: My 2001 Grand Am Idles at about 500 RPM and vibrates very rough when stopped. I think that I just need to adjust the idle however I am worried that there may be underlying issue that I am overlooking. Is it simply the idle?
BNaylor
08-22-2006, 01:09 AM
Welcome to AF.
The idle is not adjustable and controlled by the PCM module. Remove and clean the idle air controller (IAC) with carb cleaner and clean the orifice/seat at the throttle body. Also, you may have an engine vacuum leak causing the low idle and roughness.
