Ignition coil problemsUna-Ford-Able 08-21-2006, 03:20 PM i have a 87 911 porsche. the coil is getting power at the 15 terminal and the 1 terminal also, as verified by the dealer. the ohm reading is 7 across the 15 and 1. what i dont understand is, how does the coil get negative to the 1 terminal which is marked negative on the coil. does the computer make it a negative signal and if so, (which it is not doing with mine) what would cause the computer not to send the negative signal? Any help would be nice :) All the relays are changed, and i have two computers which are doing the same. The alarm system is faulty, but only for the fuel pump power which i by passed. According to the service manual, the ignition has nothing to do with the alarm. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
