1990 302 EFI- Warm start prob
micker
08-21-2006, 07:49 AM
Hi,
the truck acts like it's flooding when warmed up. have to use throttle just like old school. then it runs high idle a bit. Is there something that makes it think it needs cold start ?
Thought maybe Idle air controler, or is there choke in there? After I get going it's fine and cool starts are fine also.
1990
10-07-2006, 08:00 PM
Mine won't start when it's cold. What are you doing right? To start mine I use ethyr but after fire it's Okay. Your's may need a throttle position sensor but it's probably electrical. Check your fuel pump relay first, its cheapest.
unclebubbles
10-07-2006, 10:08 PM
Check your engine coolant temp. sensor, it can cause both hot and cold start problems. Its the one with 2 wires, the other one with one wire is for the temp gauge.
