Originally Posted by Bear
You can try by disconnecting the negative battery cable for a couple of miniutes (of course then you will need reset OBC and other cockpit functions). If this does not solve the problem a code scanner reset is in order (maybe autozone).
Thanks Bear - Yes I thought of doing that. This is the 3rd time this has happened and I am really reluctant to hoof it over to my local delaership for something so silly.
Can you explain the "code scanner reset"? And what is Autozone - another Forum?
I appreciate the response.
Les
PS I have had this fine car for 5 1/2 years with nary a problem!
