Tire weightWhitetailer 08-20-2006, 07:39 AM When researching tires and looking at the spec sheet, I see listed the tire weight. Other than the obvious that there is more material in a heavier tire than a lighter tire......... What are the pro's and con's of a heavier tire versus a lighter tire? I am looking to purchase a set of tires that are a few pounds lighter than others of the same dimentions/size. The load numbers are the same. input??? Thanks. CapriRacer 08-21-2006, 06:40 AM Weight has a loose relationship with fuel economy: More weight = more fuel consumption. Heavier tires generally ride better, but you have to make sure you have tires of similar construction: 2 plies polyester/2 plies steel/2 plies nylon does not equal 1 ply polyester/2 plies steel. Automotive Network, Inc., Copyright ©2012
