My Neon runs rough when you first start itcody_e 08-18-2006, 11:25 AM I know of the Chystler knock. It does that a lot especially when it's idling, but when I first start it it seems to miss a little and run kind of rough. This happens a lot worse if the car has just been sitting there for say 2-3 days. My fuel pump relief valve is crappy so I have to turn the key forward to get the thing to get some pressure in the line so the car will start. I'm wondering if that's my fuel pump relief valve causing the problem by not getting enough fuel to the engine when you first start it because it's bleeding the pressure or is it something else? Thanks. Neon15 08-18-2006, 06:23 PM when you say rough...you mean it sort of shakes and just doesnt feel as tight when you accelerate and brake? Part of the problem is probably just because its cold...it takes a few minutes to warm up. cody_e 08-19-2006, 02:43 AM It jerks a little when it starts up and knocks kind of loud. A guy at work told me it could be my fuel filter. Neon15 08-19-2006, 07:14 AM Rod Knock? cody_e 08-20-2006, 02:13 AM I think it has a little psiton slap. I'm not quite sure. BlazerLT 09-22-2006, 01:43 PM First, do a tuneup. Sendon, check the front motor mount. The rattling noise is piston slap and is normal. cody_e 09-23-2006, 03:41 AM That;s funny how they say piston slap is "normal." :D BlazerLT 09-23-2006, 02:03 PM On a Dodge Neon 2.0 it is normal, hell even new ones have piston slap on cold days. cody_e 09-23-2006, 02:13 PM On a Dodge Neon 2.0 it is normal, hell even new ones have piston slap on cold days. Well I think any of Chrystler's 4 banger 2.0 to liek 2.4's do it. I've heard it in a plymoth shadow and some other neons. BlazerLT 09-23-2006, 03:48 PM The shadow has the 2.2 which probably hads the rod knock which is not piston slap. Piston slap only occurs when the engine is cold and goes away once it is warmed up. Rod knock like what is heard when a shadow is running is constant all the time. Automotive Network, Inc., Copyright ©2012
