Please Help, 2k Neon Wont Start!!!!neon_323 08-17-2006, 07:09 PM My neon wont start I change the battery, but then it thru a code at me, this is it right here, & what it means. Me I have no idea what it could be. P1490(M) Low Speed Fan CTRL Relay Circuit An open or shorted condition detected in control circuit of the low speed radiator fan control relay. 97Normalneon 10-30-2006, 08:20 PM My neon wont start I change the battery, but then it thru a code at me, this is it right here, & what it means. Me I have no idea what it could be. P1490(M) Low Speed Fan CTRL Relay Circuit An open or shorted condition detected in control circuit of the low speed radiator fan control relay. Here is something that I found on Alldata.com P1490 Tests 582 - 586http://www.alldatadiy.com/alldata/AFI~V7609946~C33805~R0~OB0~P4R0H~N/0/77993956/78219291/78219292/78219294/34853741/34857029/34857030/34857663/92650819/92650832/92652766/118395354/118395355 Tests 587 - 589http://www.alldatadiy.com/alldata/AFI~V7609946~C33805~R0~OB0~P4R0H~N/0/77993956/78219291/78219292/78219294/34853741/34857029/34857030/34857663/92650819/92650832/92652766/118395354/118395356 SYMPTOM P1490 - LOW SPEED FAN CONTROL RELAY CIRCUIT WHEN MONITORED With the ignition ON and battery voltage greater than 10 volts . SET CONDITION An open or shorted condition is detected in the low speed fan relay control circuit. POSSIBLE CAUSES Radiator fan control relay circuit wire harness intermittent defect Radiator fan control relay circuit wire harness observable defect Fan relay fused ignition switch (http://www.alldatadiy.com/alldata/AFI~V7609946~C33805~R0~OD~N/0/77993956/78219291/78219292/78219294/34853741/34857029/34859584/101367270) output circuit open Radiator fan relay control circuit open Radiator fan relay control circuit shorted to ground Radiator fan control relay defective PCM (http://www.alldatadiy.com/alldata/AFI~V7609946~C33805~R0~OD~N/0/77993956/78219291/78219292/78219294/34853741/34857029/34857030/34857300) defectiveCopyright © 2006 ALLDATA LLC Automotive Network, Inc., Copyright ©2012
