need to know a part namelock_002 08-15-2006, 09:55 PM ok. i need to know what that plastic elbow thing is above the water pump. is it a freeze plug? i am leaking antifreeze from it. is it hard to replace? what does one do to replace it. thanks in advance BNaylor 08-15-2006, 09:59 PM Welcome to AF. What year and model Regal? Sounds like the plastic elbow from the LIM to the tensioner heat exchanger. lock_002 08-15-2006, 10:04 PM its a 96 ls with the 3.8 series 2 engine BNaylor 08-15-2006, 10:19 PM It is commonly called coolant elbow. To remove it you need to remove the alternator and then the tensioner assembly. Then the elbow will remove for replacement. There are two o-rings that hold it in place with a raised lip. Available at the GM dealer. Companies like Dorman and Automite make them aftermarket and you should be able to get it at an auto parts store. lock_002 08-15-2006, 10:21 PM ok thank you very much Automotive Network, Inc., Copyright ©2012
