Re: Thermal coatings?
For the downpipe I would recommend heat shield that stops heat radiation. Anything more isn't really needed.
Exhaust manifolds can be coated, they will reduce the heat loss on the way to the turbine, but not that much.
If you want to coat make sure that you get a real coating, like a plasma sprayed zirconia coating, the type of coating used in jet engines. Not that paint like shit several small companies sell. But note that zirconia is brittle.
Zirconia has a very low rate of heat transfer, that's why it's used in thermal barriers. It should not be used to reflect heat. If you want to reflect heat you want a heat shield. This may be a simple sheet of steel to the more fancy shields of inconel foil or gold coated kapton foil as found in racing cars and space crafts.
Insulation is sometimes used on racing cars and racing turbochargers. They tend to use some carbon fibre based insulation (or similar) covered up with metal foil rather than coatings though.
