Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Porsche/RUF > 924/944/968
Old 08-13-2006, 01:59 PM   #1
mkellycole
mkellycole Normal reputation
Send a message via ICQ to mkellycole Send a message via Yahoo to mkellycole
85 late 944 started after sitting valve chatter
I started my car after it was garaged for 6 months. It starts fine. I warmed it up a few minumtes while movingit. After washing it, I restarted it and there is a lot of valve chatter. I shut it down immediately. I have heard this sound on other vehicles when they were low on oil. The oil is fresh and it is full. Could the problem be just some residue from sitting? Should I start it and let it run to get some heat in the motor? The car runs great and I have never had a problem with it.
mkellycole is offline   Reply With Quote
Old 01-14-2009, 05:58 PM   #2
pjrcars
pjrcars Normal reputation
Re: 85 late 944 started after sitting valve chatter
First does the oil pressure guage show any pressure.. if it does then it could be gunge in the valve bucket on gunge in the oilway to the cylinder head. A fix we use for this and it works is to add a pint of automatic transmission fluid to the oil to clear the gunge. Once cleared change oil and filter. If you have no oil pressure indicated then check the oil filter has not unprimed itself (cheap ones do this no nrt fitted). Also check the tention of the crank pully bolt ( very very tight) it drives the pump. Lastly but least likely oil pickup tube dropped off or oil pump worn out or gunged .
pjrcars is offline   Reply With Quote
Bookmarks
Google
Web AF
