Door Lock NoiseR. Dixon 08-12-2006, 04:46 PM On my 98 crv the automatic door lock makes a buzzing noise when it engages the right passenger door lock only. It dosen't make the noise when it disengages. Can anyone help determine cause. craigf103 02-18-2007, 02:08 PM Did you ever resolve this problem? I have a CRV that is doing the same thing. Thanksl. christopher777 02-19-2007, 06:26 PM Hi there. My 1998 CR-V started doing something similar with the same door (weird noises when I went to lock/unlock it). Eventually it seized up, which I suspect was caused by lack of use. When you think about it, it's the door you probably use the least. I eventually had to forcefully take it apart from the inside, coat the locking device with a chemical lubricant, and use repeated force on the rod to force it to unlock. Once I had it open I coated it with WD-40. Now it works great. Word to the wise: keep it lubricated if it starts seizing up. c Salsa2 09-04-2007, 10:24 PM Mind does it too. Any answers????????????? Don Automotive Network, Inc., Copyright ©2012
