Buck at 65MPH, battery output of 17 AMPSkellybo01 08-12-2006, 09:33 AM New to the forum so I have several issues...... I have a 93 Jeep Chrokee 4.0 sport w/232K miles.... I am the only owner..... Issue 1 - I recently experienced an engine buck at 65 MPH, what could be the cause? I checked all the wires from the plugs to the distributor and no corrision, I did a visual check of the top ot the plugs and they looked clean (I did not pull a plug out).... also, the engine stalled at high speed (65 MPH) a few days earlier.... problem is intermittent.... it happens about every year or so, then disappears.... Issue 2 - on the dashboard my battery is showing the needle between 14 and 19 AMPS (in the red)..... it has been like this for the last 7 years.... I changed alternators but it still shows the same output? Any suggestions would be appreciated. Issue 3 - driving w/4WD engaged I get a grinding sound and car pulls to the right as if right front tire has power and left does not.... Issue 4 - I had the death wobble and replaced the track bar.... death wobble is gone.... Thanks Automotive Network, Inc., Copyright ©2012
