A/C Compressor Readings?JD68 08-11-2006, 11:36 PM My Jeep 98 Cherokee L4 2.5 Liter has not been blowing cool air for a long time, currently it is cooler than the outside air but not by much. It blows volue enough just temp is not low enough I used a Manifold hose set and got readings of: Car off 90psi Low side 100psi High side Car running 15-55psi Low Side and 100-150psi High side while the engine is running the Low side mves towards 55psi then once at 55psi the clutch engages until it drops to 15psi, while the clutch engages the High side moves to 150 psi and drops back to 100psi once the clutch disengages again. I added a can to the system to see if the clutch would engage full time but it didnt seem to take any of the can's contents, Thank you for any suggestions. JD corning_d3 08-11-2006, 11:45 PM The high side and low side pressures look low, what was the outside temp when you took those readings? You only charged thru the low side, right? Charging thru the high side port is dangerous.. JD68 08-12-2006, 12:33 AM Forgot about the outside temp, it was 78 degrees, the device I used to measure has a third hose for adding refrigerent through the low side. corning_d3 08-12-2006, 01:09 AM Was the can cold while you were charging? JD68 08-12-2006, 01:22 AM No it was warm the whole time, I expected it to cool down as the gas exited the can but the temp did not change. also I shook the can as directed before piercing the seal. AlohaBra 08-12-2006, 10:56 AM You need to reopen the tap after you pierce it, then open the low side knob. Your high side is low. Tip the can a little bit and shake it. At 80F, your low side will be around 40-45psi. High side will be above 200psi. Do not overcharge. The clutch will cycle, which is normal. MT-2500 08-12-2006, 11:26 AM My Jeep 98 Cherokee L4 2.5 Liter has not been blowing cool air for a long time, currently it is cooler than the outside air but not by much. It blows volue enough just temp is not low enough I used a Manifold hose set and got readings of: Car off 90psi Low side 100psi High side Car running 15-55psi Low Side and 100-150psi High side while the engine is running the Low side mves towards 55psi then once at 55psi the clutch engages until it drops to 15psi, while the clutch engages the High side moves to 150 psi and drops back to 100psi once the clutch disengages again. I added a can to the system to see if the clutch would engage full time but it didnt seem to take any of the can's contents, Thank you for any suggestions. JD Make sure your hose conections to low and high side are getting good connection and depressing the Schrader valves good. MT Automotive Network, Inc., Copyright ©2012
