Hi,
99 miata here.
I have been having a problem with check engine light coming on..
Code reads p1135, Heated O2 sensor bank 1 sensor input low- it is the pre-cat heater element, as I have been told by the dealer. 1)I changed the sensor with bosch universal and 3days later the same code came back. 2)Went and exchanged for another one, same after 3 days or so..
3)I went to the wrecking yard found one, off of a 99, installed it same...... 4) Ordered one from internet made for my car, made by walker. Installed it and again the same thing.
I measured the resistance across the heater element of the O2 sensor and I got 16 ohms. I went and checked for resistance in the back (after the cat) sensor and I got approximately the same value. I heard normal value for O2 sensors are 4-7 ohms (
http://www.asashop.org/autoinc/dec2002/mech.cfm).
What is the normal value form miata (California emissioned vehicle). Any of you out there have similar problem as I?
Your help would be much appreciated.
