lowering springs and PCM questions
biggustave
08-10-2006, 11:51 PM
I just wanted to know how difficult from 1-10it is to install lowering springs on a 99 alero. Should I go eibachs or is there a better brand? Also any special tools besides a spring compressor?
Also anyone have good luck with any specific place to get your PCM reprogrammed? Links etc and what kind of gains can I expect? Thanks alot
BNaylor
08-11-2006, 04:33 PM
Putting on the Eibach springs is the same as doing a regular strut job except you swap out the spring. A spring compressor is required. It is a DIY job. Afterwards alignment must be checked and you may need a camber kit.
For a DHP PCM checkout PFYC below:
http://www.pfyc.com/store/merchant.mv?Store_Code=PFYC&Screen=CTGY&Category_Code=ALUNDER
indyextremecustoms
08-12-2006, 01:44 AM
you could also go coilover setup as well..gives you the adjustabuility.
97grandamld9
08-24-2006, 11:42 PM
I dont think there is anything out there for the Alero that is worth it in terms of coilovers, all ive seen is Ebay junk.
