help pleeeeeeeeeeezzzzzzzzz!!!!!!!!!
crickie70
08-09-2006, 10:53 PM
I have a 95 jeep grand cherokee and one day i went to start it and it would just turn over and not fire, so i figured it was the coil... changed it and that did not fix the problem it wasn't the old coil had it tested and it is fine, I have no spark getting to the coil or distributor.....please give me anything, i have only until Aug 13 to fix.......Thanx....:banghead:
GregA
08-09-2006, 11:55 PM
Welcome to the forum!
Do you have any codes stored? Were there any other symptoms before it failed? My Jeep had sudden stalls, then would start up again. Finally it would NOT start back up. After that, there was a code stored (& pulled) that said something like "No Reference Signal During Cranking". It ended up being the Crankshaft Position Sensor (CPS).
If I was to guess, I would say CPS.
Take Care,
hoofan
08-10-2006, 12:11 AM
My recommendation after LONG headaches with an aftermarket CPS.
Get MOPAR!!!! (Even if you have to have a dealer install it)
7 months of misfire issues solved in 1 hour of work......(I'll post a more comprehensive review later this week)
Bryan
