Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 08-09-2006, 01:59 PM   #1
Adam194
Adam194 Normal reputation
starter bolts
i have a 1995 gmc 2500 4x4 87k on it and both of the starter bolts snapped off. a buddy of mine drilled them out and put heli coils in it but they really didnt hold up. i noticed there was a third starter mounting hole in the block i was wondering where i could get a starter that would fit that. thanks.
Adam194 is offline   Reply With Quote
Old 08-10-2006, 03:28 PM   #2
Rs051802
Rs051802 Normal reputation
Re: starter bolts
Not really sure. Why the Heli coils. Did you try a tap set? Thats a tough spot, hopefully someone on here will know what to do. I have a buddy with a 350 sitting on an engine stand for the last 3 years because of this same problem.
Rs051802 is offline   Reply With Quote
Old 08-11-2006, 02:50 AM   #3
skipr
skipr Normal reputation
Re: starter bolts
Some starters were staggered bolt, and others (the current ones I think) are forward side to side bolt pattern. I guess the mold they use to stamp out the blocks are universal for the bolt holes. I cured my problem by buying longer case hardened black allen head bolts, tapped out the same holes deeper than the one inch. A 3/8 bottom tap is what I used. This way your new bolt will go into the block further. I think one of the holes is limited on how far you can go.I used alot of Locktite 271 when re-installing. Never had problem again.
skipr is offline   Reply With Quote
Old 08-12-2006, 02:49 AM   #4
Adam194
Re: starter bolts
one of the holes is fubared good. i think i am going to try a starter out of a lt1camaro i hope that willwork
Old 08-18-2006, 09:37 PM   #5
Adam194
Re: starter bolts
does anyone know if a 6.0l starter will fit into a 95 sierra 350?
Bookmarks
Google
Web AF
