Aurora Keyless ReprogrammingLarry Sanders 08-19-2002, 09:59 AM Being a newbie to AF, I have a keyless programming question: I recently purchased a 2002 Olds Aurora (used- great car!) with one keyless fob. I got another one from the dealer w/same p/n etc., and now I would like to program it to the car. Can anyone help me on this? Trucklover[SIZE=3] Shortbus 01-02-2003, 09:42 AM Your in the same boat as a lot of other Olds owners. You cannot program the transmitters without a GM Scan tool. THis will cost you around 50 bucks at the dealer. Here is the procedure anyway. Goodluck Transmitter Programming Important All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly. Install a scan tool. Turn ON the ignition, with the engine OFF. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode. Important The scan tool must stay connected until all of the transmitters are programmed. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter. Repeat the previous step in order to program up to 4 transmitters. Remove the scan tool. Operate the transmitter functions in order to verify correct system operation. © Copyright General Motors Corporation. All Rights Reserved. -------------------------------------------------------------------------------- Document ID # 641243 2002 Oldsmobile Aurora hoot972 10-12-2003, 09:45 PM i take it this also works on 1996 auroras? 97 silverbullet 10-13-2003, 12:07 AM i never used a scan tool to reprogram my keyless entry Indy8 10-13-2003, 09:08 PM Were you programming brand new remotes? hoot972 10-14-2003, 02:47 AM i never used a scan tool to reprogram my keyless entry so how did you do it and were they new or came with the car Automotive Network, Inc., Copyright ©2012
