Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Muscle Cars > Ford
Old 08-06-2006, 03:58 PM   #1
mitchdakid
mitchdakid Normal reputation
???Adjusting lifters on 351 W
I just started hearing a slight lifter knock coming from the passenger side of the motor. I need to get it adjusted but don't have them money right now. Any idea on a way to adjust them. I have talked to a few people and they said that if you take yoru valve covers off, then start yoru engine and loosen the lifter to where you will hear it knock, then tighten it to where it stops knocking and turn it 3/4 of a turn more. Anyone ever heard of this, or have any idea how to adjust this. Thanks
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
mitchdakid is offline   Reply With Quote
Old 08-06-2006, 10:03 PM   #2
MagicRat
Might-T-Bird
MagicRat's Avatar
MagicRat +50
Re: ???Adjusting lifters on 351 W
Your friends have described the adjustment procedure that is typical of a small block Chevy.
Unfortunately, your 351 does not have an adjustible valve train (unless its been modified from stock) The rocker pedestals screw down to a fixed height and relies on the hudraulic lifter to take up the slack. If the head has been shaved, block decked or some procedure that would affect adjustment, a longer or shorter pushrod is used.
I believe there are adjustible pushrods and conversion kits (to an adjustible valvetrain) available, but I have never used them.
IMO you should check it out and look for a collapsed/sticking lifter or some kind of damage such as loose/worn/broken cam lobe, lifter, pushrod, rocker arm, pedestal and bolt, and valve.
If your engine was recently rebuilt, as it says in your sig, then there may be a problem with the new valvetrain parts and/or assembly that has contributed to an early failure. Perhaps you should take the matter up with the engine builder before you take it apart.
"We' re all here because we're not quite all there."
I still say a church steeple with a lightning rod on top shows a lack of confidence
MagicRat is offline   Reply With Quote
Bookmarks
Google
Web AF
