What are good preventive maintenance measures for the Alero?
SIYEED
08-05-2006, 09:02 PM
I have a 2001 Alero that I purchased in Feb. 2004. So far I've had to change the fuel pump, had my transmission fluid flushed, got a new gas filter (which I probably didn't need, but Precision tune suggested it), got the turn signal switch fixed thanks to the recall, and of course, routine oil and oil filter changes. My car is at 79,000 miles and it didn't come with the manual.
From your experience, what are some of the best preventive measures to take in order to prolong the life of the Alero?
GTP Dad
08-05-2006, 09:19 PM
Change the oil and filter at regular intervals, don't flush the transmission again since it can damage the clutch surfaces. Change only the fluid and filter every 30K miles, also change the fuel filter regularly and you may want to change the plugs, wires (connectors) at around 100K and keep the air filter changed for top performance. You may want to run some good quality fuel injector cleaner periodically as well.
SIYEED
08-05-2006, 09:27 PM
YOU ROCK MAN!!!! Thanks for the info. I'm illiterate when it comes to cars. Now when u say fuel filter, you're talking oil, and not gas, right? As far as the fuel injector cleaner, would I be able to do that real easy at home, or is it best to just take it somewhere. I'm so lost when it comes to cars, but I can do some kick ass stuff on a computer though, LOL
Salestax
08-07-2006, 10:48 PM
I'd tell you fuel filter every year. You cant do this too often, and its the big reason those pumps go bad. The rest of it sounds on the money.
