Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 08-05-2006, 01:13 PM   #1
01silverado03z400
01silverado03z400's Avatar
01silverado03z400 Normal reputation
Send a message via MSN to 01silverado03z400
Will 315 fit on stock rim
I recently put a 3" body lift on my truck and I'm planning on buying 315 75 16 BFG A/T tires and I'm just wondering if they will fit on the stock rims? I think my stock rims are 7" wide and the tires are 12.5" wide. On the BFG website it says they recommend at least an 8" wide rim but I've seen Ford F150's drive around with the same tire on stock rims.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
01silverado03z400 is offline   Reply With Quote
Old 08-05-2006, 02:35 PM   #2
Ape0r
Ape0r Normal reputation
Send a message via AIM to Ape0r
Re: Will 315 fit on stock rim
Can you wrestle it on there? Probably.. is it safe... ?
'04 Silverado 1500 4x4 5.3L 3.73 G80
Ape0r is offline   Reply With Quote
Old 08-05-2006, 04:49 PM   #3
01silverado03z400
Why wouldn't it be safe? What are the risks?
Also, do I need to upgrade my brakes and gear up in the rear? I have a 3.73 open differential now.
Old 08-05-2006, 10:22 PM   #4
guumbah
guumbah's Avatar
guumbah Normal reputation
Bead failure. Sidewall failure. I've seen guys have tires just pop off from being too wide for the rim, and they just popped them back on.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
guumbah is offline   Reply With Quote
Old 08-06-2006, 01:37 PM   #5
dustertwister
dustertwister Normal reputation
01silverado,
Good luck finding a qualified tire store that will actually install 315's on a stock rim. If any of them are smart they wont do it for liability reasons. I put 305's on my 01 silverado and had to buy 8" wide rims. Most recommended 10" wide rims.
Also, are you sure you can fit 315's with only a 3-inch body lift?? I put a 7-inch suspension lift on my truck and still had to cut the front bumper plastic to clear them. I would post a picture but I dont know how?
As for the rear end, remember you need to do both the axles since you are four wheel drive. I put 4.10 with an Auburn gear pro series limited slip differential in mine. I love it. I purchased my parts off ebay new and got good deals.
It is basically back to stock (from 3.73) so I still get about 17 mpg on the highway. However, I sometimes wish I would have gone to the 4.56 gears because I have a travel trailer and the 4.56 would really help on those steep grades. At the time of my installation, I was going for fuel mileage. I personally dont think you need to upgrade your brakes.
Hope this helps.
dustertwister is offline   Reply With Quote
Old 08-07-2006, 04:46 AM   #6
Rmbodie
Rmbodie's Avatar
Rmbodie Normal reputation
The MAX size for a stock alloy wheel is 285x75 . I am putting mine on 8" wheels just because I want a road and mud set that I can swap out at home . Squeezing 315's down to 7" will kill you under the right condition. rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2002 Silverado 4x4 , 5.3 Vortec . Lifted ,Pumped,Humped,Thumped!
Rmbodie is offline   Reply With Quote
Old 08-07-2006, 03:14 PM   #7
bigbadram51
bigbadram51 Normal reputation
That tire is about a 35" right. I wouldnt put it on a 7 inch wide wheel. Just asking for trouble. With only a 3" BL I think you would have to do major, major cutting and trimming to get it to fit. But if thats the way you want to go and dont want to drop the coin on a suspension lift. Here's plan B. Get a set of ford keys and crank your front torsion bars a couple of inches (that is about the max you want to go), any further and you will kill your upper ball joints and cv axles) also will make long term alignment very tough. Out back you could add another blocks to level it out or throw an add a leaf in. Even doing that, I think you will have a some good rubbing but trimming might fix that. You will also want to regear with all of that. 4.10's would be okay, but if your spending the money, you are best to go with 4.56's (yukon's are the best, precision is pretty good, stay away from Genuine) and some type of LSD (G80 LSD in the stock rear diff is a bomb waiting to go off), i.e. eaton, auburn. I say 4.56's over 4.10's because of the added unsprung weight of the tires. The stock tires weighed in at about 40 lbs, most 35's weigh 80+. The higher ratio will compensate for the added weight. A lot more info than you asked for but might help make decisions. My recco, get a suspension lift. run 37's
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Silverstar Hi/Low beams
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 35" Toyo Open Country MT's (37" Toyo MT's on the way when the 35's are done)
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
bigbadram51 is offline   Reply With Quote
Old 08-07-2006, 03:20 PM   #8
bigbadram51
Just another quick note. looks like it is feasible. will wonders never cease. this is another forum i go to and there is a thread about it. http://www.gmfullsize.com/forum/showthread.php?t=61435
3" PA Body Lift
Covermaster Top
Old 08-07-2006, 06:32 PM   #9
jumpingjack66
jumpingjack66's Avatar
jumpingjack66 Normal reputation
Send a message via Yahoo to jumpingjack66
too much tire for your rims,
yes on the brake upgrade no matter what rims you use
and what gear you need depends on where you live and what you do with the truck
I live in the mountains so i bouhgt 410 gearsin a locker rear open front diffs, and i have a 5 speed, to pull trailers....you may have different needs..if all you do is drive it around town in a warm climat i ould leave it alone untill you put some real horse power under that hood. ps uy an after market locker just my two sents...jj
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
jumpingjack66 is offline   Reply With Quote
Old 08-07-2006, 07:17 PM   #10
TexasF355F1
TexasF355F1's Avatar
TexasF355F1 +50TexasF355F1 +50
Send a message via AIM to TexasF355F1
As has been said, you can't. Get some new wheels and tires anyway, it'll look better
*Under Construction - New sig to debut*
TexasF355F1 is offline   Reply With Quote
Old 08-15-2006, 09:03 AM   #11
01silverado03z400
So according to this it will work??
Old 08-30-2006, 08:55 PM   #12
01silverado03z400
Well i ordered the tires on monday at tiretrends.com for 257$ CAN and 23$ shipping per tire and the ups man brought them to me this morning. I went straight to the tire shop to have them put on. All they had to trim was a little bit of the lower valence and a little bit of plastic on the inside of the front driver side fender. Other than that it looks awesome and im glad i didnt go any smaller. I love the stuffed look and the ride is great. The only thing that will be hard to get used to is the speedometer is out by 13 KM.
UPS man brought me a gift:
On my way to the tire shop riding 245s:
After the tire shop riding 315s:
Old 08-31-2006, 02:23 AM   #13
Rmbodie
Rmbodie's Avatar
Looks like mine now . Good job . Rob
2005 Grand Prix.
Old 08-31-2006, 07:58 AM   #14
jeverett
jeverett's Avatar
jeverett Normal reputation
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Haven't read the thread, but yes it will fit. I've seen no negative side effects fof having them and I've mounted numerous sets.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
jeverett is offline   Reply With Quote
Old 08-31-2006, 08:12 AM   #15
01silverado03z400
Ya thats what the guy at the tire shop told me except for they might wear prematurely because of the rim being so narrow, but i plan on buying new rims in spring. I sorta like the look of them on stock rims though, too bad theyre not 8" wide. My 245s seem almost low-profile to me now
Bookmarks
Google
Web AF
