Now I'm desperate and really need helpknowledge1980 08-05-2006, 12:31 PM My engine light is still on and it still running like it still needs a tune. I did everything i can to get this fix and take out this service light engine off. from changing spark plugs to checking the coil pack from even changing the 02 sensor bank1 sensor 2. Can someone please tell me what it could possible be or whatelse to check or man tell what to do at this point my brain is like really hurting and most of all when i still do the reader it still showing code p0302 GTP Dad 08-05-2006, 06:38 PM P302 indicates a misfire on cylinder #2. You stated you changed the plugs but what about the wires? The wires contribute to misfires as much as plugs. Also you didn't mention the engine size. Change the wires, if it is a 4 cyl change the plug connectors. This should eliminate the misfire. If not then the next step will be the coil or the fuel injector. SIYEED 08-05-2006, 09:03 PM Mine is 'puttering', if that makes sense, while it's sitting idle. It's like it's stumbling slightly. Everything has to be quiet in order for me to hear it. Any idea on what this could be? GTP Dad 08-05-2006, 09:15 PM Clean the idle air control motor. It should improve the idle quality. SIYEED 08-05-2006, 09:28 PM Clean the idle air control motor. It should improve the idle quality. Thanks........where exactly is that located and what is good to clean it with? I have no idea... BNaylor 08-05-2006, 10:11 PM knowledge1980, I assuming you have a 3. 4L V6. What exactly did you do with the coils. Did you switch them out with an opposing bank? You can swap coil 2/5 with 3/6 and see if the misfire shifts. Definitely do what GTP Dad suggested by looking at the ignition wires. Use OEM AC Delco spark plugs and wires only. The 3.4L is finicky when it comes to other brand parts. Two other known issues on the Alero with 3.4L is the ignition control module (ICM) and possible flaky CAT convertor causing misfire. Automotive Network, Inc., Copyright ©2012
