JDM Sr20de ECU question...g20speed002 08-17-2002, 10:08 PM I have a 95 G20 with the obdII ECU. It also came stock with the low port engine. I am halfway through swapping my JDM high port engine and have read that the OBDII will not work with this engine. Is this true? I hope its not. If anyone can enlighten me i'd appreciate it. thanks again. VTEC_hawk 01-17-2003, 03:25 PM that's a good question. I am doing the same thing to my '95 G20 (I thought 95 came stock with the high port - my JDM motor looks like it's low port? Maybe I'm wrong). Anyway, is thier ECU issues when doing the swap? :confused: kris 01-18-2003, 10:49 AM No, it will work. Make sure you swap all the sensors off your old engine onto the new one, and you will need to extend a few wires. However, you will not be able to use your egr. If your state has a visual inspection, that may be a problem. If not, you should be fine. Automotive Network, Inc., Copyright ©2012
