89 spirit brake problemdenkath 08-04-2006, 02:52 PM I have an 89 dodge spirit. I have replace the master cylinder, rotors, calipers, and wheel cylinders. I have replaced the master cylinder twice! I have bled everything numerous times. I have some brakes, but the pedal goes almost to the floor when the engine is running! I would be hard pressed to do a panic stop! I have a better pedal with the engine off. It does not seem to help by pumping the brakes. The car has about 150,000 miles. Help, I am at my witts end with this problem!!!!! demo_deven 08-15-2006, 01:34 PM 99.9% sure that you have a leak in your brake line somewhere. dylanger 02-10-2007, 06:00 AM 99.9% sure that you have a leak in your brake line somewhere. AGREED. demo_deven 02-11-2007, 04:55 PM It's probably too late now, but just try replacing all of your Brake Lines. That should be the problem. Hope I helped, Deven Automotive Network, Inc., Copyright ©2012
