Ram 150 pickup
Purple
08-17-2002, 02:31 PM
Was working on my fathers 1990 Ram 150 today and can't figure out this problem.
The truck is hard to start,when it's started,the only way it will run is if the gas pedal is pushed to a high idle.It will stop as soon as the gas pedal is released and the moter returned to normal.Fuel pressure seems good and I cleaned the contacts in the distrubuter.
Anyone have a idea what could be the problem??Thanks
jl9208
08-18-2002, 01:49 PM
Sounds like you have a vacuum leak somewhere. Check you vacuum hoses.
Come back here if still having problems
Jim:bandit: :bonghitte :bonghitte
garevalo
07-09-2003, 06:28 PM
the problem that i have is, that the engine which is a 3.9 v6, when is running is rough and when i stop at the light, it will die out, of course i can immidiately crank it up and it will run but rough again, in other words, if i let go the gas in drive, it will stall out. it runs on neutral but like i said very rough. hope someone can help me. thanks
BamaDodgenMX
09-20-2004, 03:39 AM
I'm having the exact same problem with my '88 Dodge D100 with 3.9L. Did you ever find a fix? I've replaced fuel pump, O2 sensor, etc etc, and am at my wits end!
praisethelowered
09-20-2004, 12:18 PM
Check your egr valve as well.
BleedDodge
09-20-2004, 04:26 PM
Throttle position sensor.
