Heat exchanger help 94 cherokee countryawakenedbydeath 08-03-2006, 07:52 AM Hello: I busted my old heat exchanger when I was working on my 94 Jeep Cherokee Country and when I since I have connected the new one I have no heat. I also put a new thermostat in as well. When I hooked up the exchanger I was not sure if I hookd up the hoses coming out of the firewall to the right ports. Any hep would be greatly appreaciated. AlohaBra 08-03-2006, 11:53 AM Bottom one comes from the water pump. Top one goes to front of engine where the top rad hose goes and the temp sender. You can run a water hose through the bottom one to make sure it is not blocked. Remove the top one and see if it flow. Automotive Network, Inc., Copyright ©2012
