problems getting key out of ignition
andyjs3589
08-02-2006, 11:13 PM
99 regal gs, I came home tonight and the key would not move all the way back for me to pull it out. I have had this problem before but no this bad. Before I just pushed the key forward and then pulled it back out but I tried this about twenty times and it would not slide back far enough so that I could get it out. So I finally drove it around the block turned it off and it came right out. Any suggestions as to why this could be happening and any way to correct this?
BNaylor
08-03-2006, 09:12 AM
Have you ever spilled coffee or soda on the shifter/center console. There is a shift interlock solenoid in the shifter and a key release solenoid in the steering column that can cause the key stuck problem. All part of the BTSI (brake transmission shift interlock) system.
andyjs3589
08-03-2006, 11:55 AM
I have not, but someone had the car for 125k before I bought it so it is definately a possibility. Is one of those the little black button about a half an inch long on the passenger side of the shifter? Where is the other one?
If that is the case with something being spilled on it then what can be done to correct this problem?
BNaylor
08-03-2006, 12:26 PM
Yeah it is really hard to say what happened with prior owners.
To clean, the center console would need to be removed and the shifter assembly cleaned. When in park a sensor sends 12 volts to the key release solenoid which will allow the key to move.
One way to test the shifter sending the signal up is to put ignition to on not start, step on and hold brake, then push the button on the shifter knob. You should hear the key release solenoid located at the ignition switch clunk as you do that. Then the possibility would be the key release solenoid and/or the key cylinder tumbler itself.
andyjs3589
08-04-2006, 12:29 AM
I think I know the clunk that you are talking about because I have heard a clunk a few times when doing this and then the key comes right out after that.
But I have no clue what button you are talking about that is on the shifter. Were excactly is it and do you have a pic if possible?
BNaylor
08-04-2006, 12:54 AM
The button I was referring to is the big one on top of the shifter lever you have to press down/in to get it from PARK to reverse and the other gears. When you press in on that you will hear a solenoid clunk at the steering column which is the release solenoid.
andyjs3589
08-04-2006, 02:34 AM
Oh ok, now I get it. I thought it was that tiny black button on the passenger of the shifter but I looked at that and that is like the shift lock release. I will try tommorow to hear that sound
BNaylor
08-04-2006, 02:47 AM
No problem. The one you were referring to is the one you use when the shifter is stuck like in PARK. Good luck and let us know how it turns out.
andyjs3589
08-04-2006, 08:42 PM
It takes anywhere from 3 -10 seconds for the clunk to occur. Is there any reason that there would be this delay?
BNaylor
08-05-2006, 01:14 AM
No that is abnormal. It should occur within a split second. I tested my Regal LS and GS and I hear the solenoid clunk as soon as the button is depressed.
Another suggestion is to check the 12 volts which feeds the BTSI shift interlock solenoid. Basically, your problem is 50/50 without further troubleshooting. The problem is either in the console shifter or at the steering column release solenoid.
andyjs3589
08-05-2006, 12:09 PM
How excactly do I test it? MY dad has a volt gauge that I can use it is just that I do not know where to test it
andyjs3589
08-07-2006, 01:52 PM
How much does a solenoid cost and is it difficult to install?
BNaylor
08-08-2006, 12:52 PM
With the multimeter you could check 12 volts at the fuse socket for the BTSI fuse. If that is good then I'd start at the steering column and look at the key release solenoid.
I have a procedure to remove the upper and lower plastic on the steering column and inspect the area around the solenoid and ignition switch. You do not need to remove the steering wheel. Let me know if you need it and I'll post it.
andyjs3589
08-08-2006, 01:18 PM
What fuse is it?
I do not have a manual to look this up. Is there a place that I can look this up?
Blue Bowtie
08-08-2006, 02:20 PM
Have you ever spilled coffee or soda on the shifter/center console?
Wow. I though that I was the only "lucky" one who got those...
That "delay" may indeed be the remnants of beverages in the base of the console shift stalk causing very slow release of the interlock switch. It's amazing what a little hot water and a shop vac can do to clean that up and restore almost instantaneous operation. A little follow-up coating of rust preventive (like WD-40) usually solves it until the next "Big Gulp" is poured onto the console. There's a reason older vehicles didn't have cup holders. Since accountants and marketing types have wrestled control of the auto companies away from the engineers, things just haven't been the same.
One thing you might try is to rapidly cycle the shift lock release pushbutton on the shifter handle. This can temporarily "un-goo" the mechanism long enough to get the switch (and therefore, solenoid) operating again.
I'll bet you a 64-ounce Pepsi that the problem is in the shifter/console area. :D
andyjs3589
08-08-2006, 04:24 PM
Yea I will try and test it and clean it out tommorow hopefully
BNaylor
08-08-2006, 04:57 PM
Before you tear anything apart it would be a good idea to check the 12 volts feeding the two solenoids just in case. Multimeter (preferably digital) setup in DC volts position. The delay can also be caused by a flaky ignition switch or wiring at the engine compartment fuse box. The ignition switch contacts carbon up causing a voltage drop to the solenoids. In other words acts like a resistor.
For a '99 Regal all you need to do is check two fuses in the passenger side fuse box. PARK LOCK (10 amp) located at the upper left hand side and BTSI PARK LOCK (10 amp) around the bottom left hand side. The fuse box lid has a chart you can follow for placement. Remove each fuse. Then ignition to on. Check for DC voltage on either side of the fuse socket. The 12 volts should be very close to the 12 volt reading you would get across the battery positive and negative terminals. I get 12.4 volts in my Regal GS.
If that is confirmed good then you can tear apart either the center console or steering column as suggested. Good luck!
andyjs3589
08-14-2006, 12:21 PM
I have been rapidly cycling it and it has not gotten stuck on me. So I will just do this and if it gets worse I will test the voltage and/or clean out the shifter
Thanks everyone for your help,
Andy
slyfox70
03-29-2008, 03:42 PM
You stated that you have a procedure on removing the upper and lower plastic on the steering column. Could you post that information. I have the lower plastic off but having problems with the upper piece. Thanks
BNaylor
03-29-2008, 05:25 PM
See this link below. Good luck!
http://www.automotiveforums.com/vbulletin/showthread.php?t=653340
