Using Jack Stands
kmantle
07-30-2006, 06:13 PM
Unfortunately the front jack points on my Lumina appear to be missing. There's an arrow that points to a part of the underside that does not look reinforced for jacking like it does at the rear. Well, it did look like the rest until I jacked it up where it said and now it's just a little bent out of shape. I was wondering what other points on the chassis can be used for lifting the front of the vehicle with a floor jack and then supporting it with jack stands. Is there a standard place where these can usually be used on any car without damage?
knuckle ears
08-01-2006, 08:02 PM
I would use your floor jack. Jack up the van on one side at the engine frame. It is the ones with the round rubber mounts underneath the van. Install your jack stands under that frame also. Lower the floor jack and do the other side.
Block the back tires so it doesn't roll.
Put a device under each front side so if the van falls it will not crush you if it breaks or tips and falls(tire rim, large log, etc) I have trusted jack stands and ramps for along time but you never know when that time ends.
EZcarlift Fan
10-21-2008, 02:47 PM
i use the ezcarlift that does the jacking and the holding of the whole car, so no need to lift, then hold with jack stands.
it is basically the lift and the stand that raises the whole car at the same time.
'97ventureowner
10-21-2008, 03:19 PM
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
