06 GMC Sierra 2500HD Automatic Headlights/DRL's
tinstar
07-30-2006, 05:58 PM
Does anyone know how to disable the automatic function of these.
I like to turn on my own headlights and turn off my DRL's
I know you can do it everytime you start up, but it's becoming a real pain to do it that way.
Thanks!!
bzieman2
07-31-2006, 09:58 AM
I know what you mean. I had the same problem. Let alone the heat from them being on destroys the clear lense after a while. I just took the bulbs out, cut the little wires on the back of the bulb off, put them back in. This way if I change my mind, all I have to do is buy two new bulbs. Hope this helps
tmacmiller
08-01-2006, 05:14 PM
Yes, go in the fuse box and take out the fuse for the DRL. It is sometimes combined with fog lights though.
tinstar
08-05-2006, 09:56 AM
I took out the DRL bulbs so that solves that problem. Couldn't find a fuse labeled as such.
My 98 was easy to do just by pulling the fuse.
Is there a fuse that controls the sensor that turns on your headlights automatically?
I can't stand this feature!
Thanks!
Bill-SILV
08-16-2006, 11:47 PM
I think with your engine off you press the dome overide button 3 times in and out and the truck will make a ding noise and that disables the lights from turning on.
tinstar
08-18-2006, 08:05 AM
I will give it a try!
Thanks!!
tinstar
08-20-2006, 09:26 AM
No luck.
Thanks
Bill-SILV
08-20-2006, 11:55 AM
I know, I found out last night on mine. I went to the drive in and had to turn the switch everytime I turned the truck on to run the air because it was raining.
