trouble codeslions83 07-28-2006, 10:15 PM 94 jeep codes 12,21,54,55, light comes on but once you restart it , it goes out until it comes on again, . could it be a small leak in the intake system Bob D. 07-29-2006, 06:15 AM This is the info I have on codes-- Code 12: Direct battery input to PCM was disconnected within the last 50 key-on cycles. 21: Neither rich nor lean condition detected from the oxygen sensor input. 54: No fuel sync (camshaft signal) detected during engine cranking. 55: Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp). Code 21 sounds like a bad O2 sensor, 54 a bad cam sensor. Automotive Network, Inc., Copyright ©2012
