Battery light problems..firefighter413 07-28-2006, 04:41 PM I have a battery light that has a mind of it's own. It comes on and off when it wants to more on now than off. Also you can be driving down the road at 55mph and the car will shut completely off all the gages work but the motor dies. I have changed the alta. and also the battery it hasen't made any diffrence. I have hooked it up to a di-o machine it will not tell me anything any diffrent either. I have also replaced the belt as well as the hot and ground cables to and fraom the atl.Does anybody have any idea how to fix this problem?I have spent to much I need some answers please...thank you:banghead: pre98zetec 07-28-2006, 05:00 PM check the wires fromt he altenator to the battery, Check if the belts slipping. firefighter413 07-28-2006, 05:15 PM check the wires fromt he altenator to the battery, Check if the belts slipping. thanks for the replay but I have already done that. I put a new belt on and also replaced all the ground and hot cables to and from the atl. Got any other ideas beyondloadedSE 07-28-2006, 06:03 PM thanks for the replay but I have already done that. I put a new belt on and also replaced all the ground and hot cables to and from the atl. Got any other ideas did you replace the alternator relay? KimMG 07-30-2006, 05:40 PM Did you check and clean the connectors on battery cables? firefighter413 07-30-2006, 07:08 PM YES I CHECKED ALL THE CONNECTIONS AND CLEANNED THEM. WHERE IS THE ALT. RELY i WASN'T AWARE OF THIS.. beyondloadedSE 07-31-2006, 02:56 PM YES I CHECKED ALL THE CONNECTIONS AND CLEANNED THEM. WHERE IS THE ALT. RELY i WASN'T AWARE OF THIS.. Im hoping you have the V6. If you do, right behind the rear valve cover is a wiring harness. Pop that open and youll be able to see the megafuse. firefighter413 08-01-2006, 04:04 PM I am sorry to say no I do not have a v6 it is a 4cyl...this car belongs to my wife and I am afraid for her to drive it because it is dieing. I have put so mush money in it I really appreciate any help anybody can give me.... Automotive Network, Inc., Copyright ©2012
