Re: vaccum test
p0171- oxygen sensor detects lean condition
p0441- evaporative emissions incorrect purge flow
A cracked, broken or disconnected vacuum line could cause both codes, so I'd look at all the underhood vacuum lines for damage. When he did the head gaskets, did he use good quality gaskets to do the job and torque everything to spec with a good quality torque wrench? If all the vacuum lines check out, spray wd-40 or carb cleaner (be careful to keep it off hot exhaust manifolds) around the throttle body mounting area, lower intake, etc... If the idle changes when you spray an area, you have a vacuum leak there.
Would you drive any better with that cell phone up your ...?!
