Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 07-26-2006, 08:13 PM   #1
Doug_Guilds
Doug_Guilds's Avatar
Doug_Guilds Normal reputation
Valve springs?
I am looking to get new valve springs for my 89 3.1. Its a stock grind cam with the comp cams 1.6 ratio rockers, but seems to fall off pretty bad after about 3500 rpm. What company has a good set of springs?
Doug_Guilds is offline   Reply With Quote
Old 07-27-2006, 06:06 AM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: Valve springs?
There is no reason to go to performance valve springs unless you have a high-lift cam. Higher spring pressures equal more friction which equals less horsepower. GM stock springs are good for 6,000 rpm, and I doubt you'll be taking that old style, zero lash 3.1 any higher than that.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 07-27-2006, 08:08 AM   #3
maxwedge
A990 racer
maxwedge Normal reputation
Exclamation Re: Valve springs?
Agree with Rich, a stock 3.1 170k miles pulled good to 5k, something else is going on here. I cannot see 1.6 rockers on a stock cam causing valve float.
maxwedge is offline   Reply With Quote
Old 07-27-2006, 02:39 PM   #4
Doug_Guilds
Re: Valve springs?
Well this thing is stock except the rockers, but the engine does have 224,000 on it. I definately don't want it to go over 5500 rpm, so a new set of stockers from GM should do nicely then.
Thanks guys.
Old 07-27-2006, 03:04 PM   #5
maxwedge
A990 racer
Red face Re: Valve springs?
Thanks guys.
The pcm will limit the engine rpms here, is this what is happening, if so valve springs, again will not help. How did we go from 3,500 to 5500? You are modifying a 224k engine, relax , you are flirting with disaster trying to squeeze more rpms here.
Old 07-28-2006, 01:04 PM   #6
Doug_Guilds
Re: Valve springs?
Oh it has rpm, it just doesn't seem to pull hard after 3500.
Old 07-28-2006, 04:15 PM   #7
maxwedge
A990 racer
Question Re: Valve springs?
Did it before you worked on it when did this change? Power is down on any engine with that mileage, how is the fuel pressure under load.
Old 07-28-2006, 08:13 PM   #8
Doug_Guilds
Re: Valve springs?
No, it felt pretty much the same. It has an inline fuel pump, cause it has a fuel cell in it, so unless it's a regulator problem that shouldn't be an issue. It's a MiniStock dirt car that I race at the local dirt track.
I am going to redo the engine after the season is over, but would like to get what i can out of it the next 4 races, that's when our points end.
Old 07-29-2006, 03:38 PM   #9
maxwedge
A990 racer
Unhappy Re: Valve springs?
So after all this, you now tell us what the real deal is here, nice curve ball for trying to help you based on the lack of definitive info!! Check the fuel pressure at the rail under load!
Old 07-31-2006, 08:08 PM   #10
Doug_Guilds
Re: Valve springs?
What the heck are you talking about? The real deal was I wanted info on valve springs, and Rich answered my question very well. Then you mentioned another potential problem. Ok cool, but if you needed all kinds of application info, fuel system specs, and exact mods done why didn't you say so?
Thank you for the advice.
Old 08-01-2006, 03:37 PM   #11
maxwedge
A990 racer
Re: Valve springs?
You are trying to connect your performance issue with the supposed weak valve springs, without " all" the info related to your issue we are second guessing as condition that can be related to the general configuration of the engine, remember we are sitting at a desk trying to visualize what is happening.
Old 08-01-2006, 04:37 PM   #12
Doug_Guilds
Re: Valve springs?
PM sent Max.
Bookmarks
Google
Web AF
