Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-26-2006, 10:44 AM   #1
gelcol
gelcol Normal reputation
ignition off , while starter still cranking
can anybody solve this? after I turn the ignition off , the starter still cranking for a few seconds before it shots off.
got a yr.2000 4cylinder camry .
gelcol is offline   Reply With Quote
Old 07-26-2006, 11:13 AM   #2
ponchonutty
ponchonutty's Avatar
ponchonutty Normal reputation
Re: ignition off , while starter still cranking
do you have a remote starter installed?
2004 Dodge SRT4 <<<<SOLD!!!!
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
ponchonutty is offline   Reply With Quote
Old 07-26-2006, 11:34 AM   #3
Mike Gerber
AF -Advisor
Mike Gerber Normal reputation
First, locate the starter relay so you will know where it is for the next time this happens. Then when it does, quickly go out and tap the relay. If the starter disengages, then you have found the problem. Go out and replace the relay. If this isn't the problem, then the next thing to check would be the starter bendix drive itself. Locate the starter. Then have a small hammer or wrench handy for the next time this happens. When it does, go tap the starter itself. If the starter now disengages, the starter's bendix drive is sticking in it's outward/engaged position. Best to replace the starter.
Mike
Mike Gerber is offline   Reply With Quote
Old 07-26-2006, 05:38 PM   #4
gelcol
no remote starter.
Old 07-26-2006, 05:40 PM   #5
gelcol
Mike
where's the relay usually located?
Old 07-26-2006, 08:42 PM   #6
ponchonutty
OK then it's either the starter relay (located in engine bay fuse block, ck manual for which one) and you can just swap that relay with a simular one that's next to it to test. The other 2 possibilities are bad starter or bad ignition switch.
Pioneer 4900mp
Orion C63 Coax rear
Old 07-27-2006, 12:41 PM   #7
gelcol
2nd day it did'nt happen, starts normal and turn ignition off normal.
Thanks for your help .
Bookmarks
Google
Web AF
