Spark Plugomani 07-24-2006, 04:34 AM HELLO ALL, I'V GOT A 1jz TWIN TURBO ENGINE ON MY TOYOTA SOARER (SC300).. I WAS SEARCHING COUPLE OF HOURS AGO ON THE NET FOR HIGH PERFORMANCE SPARK PLUGS FOR MY CAR, BUT WENE I SEARCH UNDER LEXUS, I GET THE SC300 WHICH IS 3.0L AND ITS NON TURBO.. AND WENE I SEARCH UNDER SUPRA, I GET THE 2JZ AND THATS A 3.0L TWIN TURBO.. SOO I DNT REALLY KNOW WHICH TO PICK.. CAN SOME1 RECOMMEND A HIGH PERFORMANCE SPARK PLUGS FOR MY 1JZ.. I USE THIS CAR FOR AUTOCROSSING.. AND SOMETIMES STREET RACING.. IM LOOKING FOR THE BEST SPARK PLUGS.. THNX.. TcmaBoy 07-24-2006, 11:21 AM The 1JZ and 2JZ share the same plug. I am running Denso iridiums in my 1JZ. If you are deep into your Soarer then you should check these guys out: http://au.lexusownersclub.com/forums/ Yashveen 11-28-2006, 01:40 PM i run Denso Iridium..does the job well... you could also run NGK which are pretty good.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
