Thinkin about a dieselShadowmtu 07-23-2006, 09:15 PM Alright, it's my first time postin in the threads. I have an '03 1500 Silverado and it's just your base work truck with a 4.3L. What I wanted to do was drop in a diesel. I just wanted to see if anyone had any advice on what engine to get and which tranny I should use (prefer a manual). Any help would be appreciated. Thanks. bigbadram51 07-24-2006, 02:32 AM Im not sure if just adding a diesel engine in a 1500 is either economically feasible or easy to do. I could be wrong, but seems too me that you would have to do so much to the suspension, frame, motormounts, and espically drivetrain to get that big ol heavy diesel just to fit inside the much smaller, and less stout 1500 frame, IMHO you woule be better off just buying a 3/4 ton. I know that Truck Trend, Four Wheeler or some magazine, was turing a 1500 into a LLY D-max drag truck. If you do it, mad props to you, gonna be sweeeet!!!!! silverado122775 07-24-2006, 01:26 PM I think it would cost you more money than it is worth. Buying a truck with a diesal is the better chose.. Like what was stated by ram51. you would have to beef up the frame, suspension, mounts and get a taller hood. you will also have to upgrade your brakes and rotors as well. A small block v8 can weigh up to 500 lbs, a diesal can weigh up to 2000lbs. You can look at the stats on Chevy , dodge, or ford. Look at the weight differance from a 2500 with a diesal compared to one with a V8 unleaded. gremlin96 07-27-2006, 07:18 PM Alright, it's my first time postin in the threads. I have an '03 1500 Silverado and it's just your base work truck with a 4.3L. What I wanted to do was drop in a diesel. I just wanted to see if anyone had any advice on what engine to get and which tranny I should use (prefer a manual). Any help would be appreciated. Thanks. http://www.saturnsurplus.com/ you can get a cheep exmil truck. depending on ware you are thay run around 5,000. not bad for a used and abused truck. for that price you realy cant beet it for a diesel. Automotive Network, Inc., Copyright ©2012
