2003 V8 laredo ?
Stringecheese
07-23-2006, 11:06 AM
Hi Again.
I was looking at a 2003 laredo with 78000 miles on it. It drives good but there is a problem with the breaks. Probably the rotors need to be turned. Also the tires are bald and need to be replaced. This is at a dealership. Other then those problems it is very clean and drives nice. The lowest I can get them on it is 11780. Does this seem like a good price. They did say they would look at the brakes and that 2 new tires are shcedualed to be put on it. What do you think?
msrjeep
07-23-2006, 02:12 PM
tell them you want 4 new (matching)tires, new rotors, new pads, and check the front CV axle boots for leaks, if they leak grease that can cause your rotors to wear unevenly. and then give them the 11,800. check http://www.wjjeeps.com/tsb.htm and see this jeep has any of the other common issues. Does it have all service records? tell them they can't get full retail price if it's not in perfect condition(except a little normal wear). and who gets book value for a used car anyways...
