Serpintine belt
Google
Web AF
guzzigreg
07-23-2006, 07:58 AM
Need help changing Serp Belt. Can anybody tell me how hard it is. Also is there anything I can read and possibly see Pics of the job. Should I change the idler rollers? My 97 has 90,000. The first two times my dealer has done the job. Trying to save money. The belt is glazed and getting small cracks.
Thanks
rlith
07-23-2006, 09:02 AM
Unless you're hearing squeaking on the idler pully when you turn it by hand, you don't need to swap it out.
Using a 16mm socket and a long ratchet (or breaker bar) or link to box wrenches together, rotate the tension pully counter clockwise and remove the belt...
The diagram for routing should be on your core support.
hunter01
07-23-2006, 11:34 AM
Put it in the clothes dryer for 10 minutes to soften it up and take out the kinks.
jd-autotech
07-23-2006, 11:49 AM
pay attention there should be a label diagram under the hood called a belt routing diagam showing you how to route the belt study it before you start. and along with the previous posts the jobs a peice of cake
MT-2500
07-23-2006, 11:52 AM
10-4 on that.
But if someone has removd it take a picture of it before removing.
You have gotta get them wrapped up just right.
Good luck MT
blazin911
07-25-2006, 10:39 PM
diagram should be on the radiator shroud
muddog321
07-26-2006, 08:32 AM
Simple if when you remove watch how it comes off. I put gloves on and just push the tensioner in and slide the belt off the top idler fixed pulley and then slowlty release the tensioner - reaching behind the tensioner to get a wrench on it was/is always a pain and it slips off. Install is reverse but if you have weak arms use the wrench. Idler goes too and about $25. The tensioner is more and aftermarket ones are a cheaper design than GM.
guzzigreg
07-28-2006, 08:47 AM
Thanks to everyone for the help. Job took all of 15 Min. Hardest part was waiting for parts at the dealer.
Greg
diannap
10-06-2007, 07:16 PM
anyone know how to get the diagram if it is not on the car?
MT-2500
10-06-2007, 07:50 PM
AZ web site may have it.
MT
ZL1power69
10-07-2007, 01:08 AM
thread is now over a year old.
Google
Web AF
