Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 07-22-2006, 06:35 PM   #1
kimbergross
kimbergross Normal reputation
need help high beams
my high beam are both out i change bulbs and light switch . any buddie know what is wrong or what to check thank for any help i check the fuse too. and they are all good.
kimbergross is offline   Reply With Quote
Old 07-22-2006, 07:53 PM   #2
94VL
94VL Normal reputation
Re: need help high beams
Dimmer switch?
94VL is offline   Reply With Quote
Old 07-22-2006, 09:13 PM   #3
jakegday
jakegday Normal reputation
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
by dimmer switch i think he means the switch you use to go back and forth from regular to high beams, is that the switch you replaced??
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake
1981 Fairmont 6cyl 3 speed
jakegday is offline   Reply With Quote
Old 07-23-2006, 07:20 AM   #4
kimbergross
yes that is the one i replaced
Old 07-23-2006, 07:22 AM   #5
kimbergross
Originally Posted by 94VL
Dimmer switch?
i replaced that thanks
Old 07-23-2006, 11:32 AM   #6
mstr3000
mstr3000 Normal reputation
did you check the connectors at the back of the bulbs? if they are not properly seated, it will cause that problem
mstr3000 is offline   Reply With Quote
Old 07-23-2006, 01:00 PM   #7
94VL
Do you have those High performance high wattage "off road use only" bulbs? If so,the amp draw these take can melt wires and ruin sockets.
Old 07-23-2006, 01:07 PM   #8
kimbergross
yes i check connector i even re check bulp with my 1997 and they worked in it but not in the 1999 thank for info kimber
Old 07-23-2006, 01:12 PM   #9
kimbergross
no i do not have high performance bulbs thanks kimber
Old 07-23-2006, 02:39 PM   #10
Cap0ni
Cap0ni Normal reputation
take a volt meter to them and see if your getting anything through. trouble it back untill you find where tyour not getting them switched. you may have a short or faulty wiring somewhere not always a switch.
its been awhile since i had the column apart but i believe its the brown wire in your assembly inside the console, a voltmeter or wiggy will tell you for sure tho, since youve already replaced the bulbs and switches check the wiring.
Cap0ni is offline   Reply With Quote
Old 07-23-2006, 03:04 PM   #11
kimbergross
i dont know much about wiring can i replace the front wiring harness thanks kimber
Bookmarks
Google
Web AF
