Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 07-22-2006, 03:18 AM   #1
babalon1
babalon1 Normal reputation
Exclamation I need a explanation of head unit wiring
my vehicle is a chevy cav 1997 sedan
ok i have a sony explod Cdx GT20w and a mounting kit. In the sony box theres some kind of wire connecter that attaches to the back of the unit and on the other end is loose colored wires. this is the stereos harness right? and so i connect them to the cars harness thats already in there? So do i have to remove the stock cars head units harness and solder or crimp to where the stockon were connected.
here are images so can i just connect these loose wires with the ones on the existing harness in the car according to color. But what are these cables for as shown in images the one that looks like a crab claw and those 2 wires with plastic tips that say "ant rem max 0.3A and 0.1A"
thanx for help im sorry if im annoying anyone
babalon1 is offline   Reply With Quote
Old 07-22-2006, 03:34 AM   #2
jakegday
jakegday Normal reputation
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: I need a explanation of head unit wiring
there should be 2 wiring harnesses, one for your stereo, and one for your car, both of those harneses have loose wires that you need to attach to each other.... alot of the time they're even color coded
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
jakegday is offline   Reply With Quote
Old 07-22-2006, 01:00 PM   #3
my99cavy
my99cavy's Avatar
my99cavy Normal reputation
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
the ones with the plastic tips are your remote wires. dont have to mess with those unless hooking up subs or something else of that sort.
Originally Posted by Oz
The most difficult part of buying a moped is telling your parents that you're gay.
Originally Posted by beef_burrito
i don't need that cat to satisfy me, all i need is a woman..... but my hand with lipstick on will work just as well..... and has.
my99cavy is offline   Reply With Quote
Old 07-22-2006, 07:57 PM   #4
noshun
noshun's Avatar
noshun Normal reputation
ok take that connector and go but one from Best-buy or a stereo shop that will work with 97 cav. Then attach the corresponding wires from each to each other and install the deck. Two ways to connect it, solder and heat shrink (or failing the heat-shrink just electrical tape) the wire should say what they are on both connectors. The colours don't usually match up. It's not usually a good idea to remove the stock connector as the wire in GM cars aren't consistent with any other system. The other wire with the plastic should say what they are for or the manual for the deck will. This way you can connect the wires out of the car and then just clip into the car and slot the deck in once the mounting kit is installed. Also the antenna, the typical size on all decks is Motorola but gm decided to use a smaller one, you will need that also. Some Harness kits do come with this though. I believe a Scoshe one ddoes and you can pick those up at wal-mart
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
noshun is offline   Reply With Quote
Bookmarks
Google
Web AF
