Weird Occurance in my Intrepid
jl9208
08-13-2002, 01:35 AM
[SIZE=3][FONT=century gothic][COLOR=teal]
Here's what happened.
All of the sudden....Out of the blue my headlights won't work from the switch. Whenever I open the doors my parking lights come on all by themselves (Front & Back) and they stay on for aprox 10 minutes after I close the doors!
The headlights will work on HIGH BEAM if I pull back on the turn signal and hold it there. I checked every fuse and relay both in the fuse panel and under the hood and they are all good.
The headlight switch doesn't do a thing, because as soon as I open the door BAM! the parking lights come on.
Any ideas?
Thanks
Jim (Phx_Az)
DVSNCYNIKL
08-13-2002, 08:10 AM
Probably a wire is loose or touching. Have an electrician run through it and I'm sure he'll find it. Don't worry, it won't be expensive.
duncanjeffrey
02-01-2004, 03:48 PM
Hey, did you have any luck with you Intrepid. My '99 is having the same type of electrical problems. Thanks.
