96 dodge ram 5.9 360 has problems coming up steep hill Misfires and backfiresbratt 07-20-2006, 02:05 PM my friends 96 dodge ram 5.9 v8 360 has problems coming up a steep hill almost every time but not every time it will start sputtering and the check engine light will start flashing. it will make it up the hill but it has trouble on the flat roads it works fine even the freeway its perfect only on the hill do i have problems i checked the engine code and it says random misfires misfire cylinder 1 misfire cylinder 2 misfire cylinder 3 i have new spark plugs is it my cat? BleedDodge 07-20-2006, 11:19 PM i have new spark plugs New Autolite spark plugs? bratt 07-20-2006, 11:25 PM yes they are autolite Slade901 07-24-2006, 08:53 AM Just make sure you check the ignition coil terminal to make sure it's not corroded and if it is corroded then clean it with sand paper. Automotive Network, Inc., Copyright ©2012
