idiots lights?Ridleyj329 07-19-2006, 03:28 PM does anyone know where i could find any diagrams to show me what each light on my dash means? sierrap615 07-20-2006, 12:24 AM check in your owners manual PlayStation3 07-20-2006, 10:56 AM most are self explained though. G-man422 07-20-2006, 11:00 AM Is there a specific one you need to know? Ridleyj329 07-20-2006, 01:32 PM yeah. but i dont have an owners manual. its the symbol of a box with a + in it and what looks like a flag pole with two wavey lines coming off it. its on a 94 SL1. a buddy of mine told me its a temp light. but everything seems fine. the light only blinked and he said not to worry about it. G-man422 07-20-2006, 01:44 PM sounds like the water temperature light. sierrap615 07-23-2006, 12:58 AM on the S-series a BLINKING low coolant/temp light is a sign of a possible bad ECT due to some funky programing in the PCM i don't understand Ridleyj329 07-25-2006, 06:04 AM whats an ECT? brokenplastic 07-25-2006, 09:56 PM Engine Coolant Temperature sensor Ridleyj329 07-26-2006, 09:06 PM ive already replaced that brokenplastic 07-26-2006, 10:10 PM How long ago did you replace it, and did it have a metal or plastic tip? Ridleyj329 07-28-2006, 09:33 PM i dont remember when i replaced it. it would have to be at least a month or two ago and it had a metal tip on it. why? brokenplastic 07-28-2006, 11:09 PM The plastic tipped ones are known to fail prematurely. Did you replace the one with 2 wires, 1 wire, or both? Ridleyj329 07-29-2006, 01:56 AM only the two wire brokenplastic 07-29-2006, 07:49 AM Go ahead and pull the 1 wire sensor, see if its plastic tipped, if so replace it. sierrap615 08-02-2006, 01:53 AM the one wire sender's ONLY propose is for the needle gauge on the dash, it is not for any lights. if the sensor has been replaced, check the connector for gunk. check coolant level, purge any air from the system(squeeze hoses and watch for bubbles in resevuior). i will try to find out the exact cause of this warning via the computers at work, but tiny rare part of programing like this tend to be omitted Automotive Network, Inc., Copyright ©2012
