passinger side front axle
Btd36
07-18-2006, 10:50 PM
Hello,
Can anybody tell me how I get the front passinger side axle out? I need to replace the balljoints and u-joints and i'm having trouble with this.
Thank You,
Brian
wv ranger
10-19-2006, 03:04 PM
Right axle is held in with c clip. must remove brakes, rotors, spindles. Left axle will pull out.pull right axle off splines. drain and remove differential. also disconnect front driveshaft. after differential is out, rotate pinion until you can see c clip. snap it out and the axle will pull out. I have just finished doing this to my truck, its an all day job.
