1989 tail lights
rdeckert
07-18-2006, 03:09 AM
Okay, so my tail lights will work, just not while my headlights are on. If I put the parking lights on and pull just a touch more, then the rear lamps will go on. So I can eliminate a fuse or bulb problem seeing as I've already changed the fuse. So the only thing I can think of would be a faulty pull switch. I can't afford to get it fixed. And ideas on a quick fix?
(One idea was for me to reroute the wire(s) from the switch to something like my heater switch. I know it could work but I don't even know which wire would be it. Does it even run behind the radio?)
Help would be greatly appreciated. Thank you.
RIP
07-18-2006, 03:34 AM
Zip on the quick fix but, I'd be shocked if a junkyard charged you more than $10 for the switch. Check around.
rdeckert
07-19-2006, 12:55 AM
Good, but I don't even know how to go about replacing a switch. I've nevcer done it before. It's a knob pull switch.
RIP
07-19-2006, 01:24 AM
This might help: http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/10/cb/f3/0900823d8010cbf3.jsp
