idle problem with my 96 Ram 1500jscheuffele 07-14-2006, 09:35 AM Hey everyone, I'm pretty new to this, but I need some help. I just got a used 96 Dodge Ram 1500 V-6 manual pickup. While I drove it with the A/C off, it runs great. When I turn the A/C on, even to the lowest setting, the truck dies every time I stop or take my foot off the gas. I have changed out all of my plugs and wires and that didn't fix the problem. I thought that it might just be an idle problem, but I couldn't find the low-end idle adjustment screw for it. Does anyone have any solutions, or at least a picture of where the adjustment screw would be on this engine? Thanks for any help! Austin8214 07-15-2006, 08:34 AM this may sound way off base but check your alternator output. You may also have a weak battery. jscheuffele 07-15-2006, 07:50 PM I know the battery is strong, but how do I check the output of the alternator? I have a voltage meeter on it, and it checks out ok. It also starts right back up again once it dies. Thanks. Austin8214 07-17-2006, 06:26 AM I know the battery is strong, but how do I check the output of the alternator? I have a voltage meeter on it, and it checks out ok. It also starts right back up again once it dies. Thanks. You need to check it with a hand held multi meter. The one in the truck is not accurate to say the least. The alternator should be putting out 14volts to charge the battery properly. You can check this with the truck running and your ac on you should be getting 14 volts at your battery. scoutinkeith 07-17-2006, 10:01 AM I'm not to familular with the V-6 engines, so this my not be much help, but on the V-8 engines(5.2 and 5.9), there is an Idle Air Control(IAC) valve/actuator that sometimes gets cloged, and doesn't function properly. again, on the V8's, when at idle, the throttle blades are compleatly closed, and the IAC is what controls the amount of air going to the engine. if it's stuck, and can't move freely, it may not be able to increase the idle enough to keep the engine running with the extra drag of the AC compressor. jscheuffele 07-17-2006, 10:32 AM I'm not to familular with the V-6 engines, so this my not be much help, but on the V-8 engines(5.2 and 5.9), there is an Idle Air Control(IAC) valve/actuator that sometimes gets cloged, and doesn't function properly. again, on the V8's, when at idle, the throttle blades are compleatly closed, and the IAC is what controls the amount of air going to the engine. if it's stuck, and can't move freely, it may not be able to increase the idle enough to keep the engine running with the extra drag of the AC compressor. If there were a clogg in the IAC, would that show up on an OBD II diagnostic scan? I did one of those and it came up clean (no error codes). How else would I check to see if that were the problem? Thanks jscheuffele 07-17-2006, 11:30 AM You need to check it with a hand held multi meter. The one in the truck is not accurate to say the least. The alternator should be putting out 14volts to charge the battery properly. You can check this with the truck running and your ac on you should be getting 14 volts at your battery. I checked the voltage with the A/C on and off and the readings came out to 13.65 V with it on, and 13.69 with it off. It's a little low, but is that low enough to cause the idle to drop and the truck to die? scoutinkeith 07-17-2006, 12:07 PM If there were a clogg in the IAC, would that show up on an OBD II diagnostic scan? I did one of those and it came up clean (no error codes). How else would I check to see if that were the problem? Thanks I'm not sure if it would show up or not. I kinda doubt it, since the IAC is NOT a sensor, it's just a little actuator and plunger. as far as checking it, on the V-8 engines, the IAC is located on the back side of the Throttle Body, and can be removed by taking out two torx screws, and unplugging one electrical connection. you'll want to look for excessive buildup on the end of the plunger, as well as on the Throttle Body where the plunger seats. also, there is a little rubber O-ring that seals the IAC housing to the TB, be carefull not to drop it when you pull the IAC off. once you have it off, just spray it, as well as the throttle body, with some carb/TB cleaner to remove any buildup, and reinstall. also, you'll want to disconnect the negative battery cable to reset the computer once you have the IAC reinstalled. Austin8214 07-18-2006, 01:02 PM I checked the voltage with the A/C on and off and the readings came out to 13.65 V with it on, and 13.69 with it off. It's a little low, but is that low enough to cause the idle to drop and the truck to die? 13.6 should be fine. I would now check out the IAC as scoutinkeith suggested. jscheuffele 07-18-2006, 05:45 PM Ok, I took off the IAC and looked inside... it looked pretty clean. I sprayed it with the cleaner and put it back together, after disconnecting and reconnecting the negative battery cable, I took it for a test run, and it did the same thing. Is there anything else that would be causing it? Thanks for your help! scoutinkeith 07-19-2006, 08:58 AM dose the AC seem to be working correctly? my only other guess would be that the compressor isn't spinning freely enough, and bogging down the engine. however, if that were the case, I'd expect that the belt would squeel before the engine would die. jscheuffele 07-19-2006, 09:12 AM The A/C works fine. There is a belt that squeels occasionally, but it squeels when the A/C is on and when it's off... and doesn't die right afterwards. It doesn't seem to have any direct connection to the idle problem... at least to me. jscheuffele 07-21-2006, 09:02 AM I do have a leek in my power steering pump, that I need to fix. Could that, somehow, be the problem? 89ltd 07-23-2006, 10:28 AM The computer should compensate and bring the idle up via the iac valve when you turn the a/c on. I'll have to find a wiring diagram to see what tells the computer that the a/c is on. Slade901 07-24-2006, 08:46 AM More than likely the ac compressor pulley is seizing up when the ac clutch engages when you turn on the AC. jscheuffele 07-25-2006, 12:53 PM More than likely the ac compressor pulley is seizing up when the ac clutch engages when you turn on the AC. If the compressor pulley was seizing up, wouldn't the A/C not work? How would I check to see if it were seizing? Slade901 07-26-2006, 12:19 AM If the compressor pulley was seizing up, wouldn't the A/C not work? How would I check to see if it were seizing? If the belt squeels when you turn on the AC then the belt is having difficulty spinning the ac compressor pulley when the ac clutch is engaged and the belt is rubbing off the ac compressor pulley and you hear that belt squeeling noise. You don't hear the belt squeels when the ac is not on because the ac pulley is rotating along the direction of the belt routing. Once the ac is turned on then the ac pulley is partially stuck and won't rotate easily and so the belt is now sliding off the ac pulley and makes the belt squeels. jscheuffele 07-26-2006, 08:22 AM The belt squeels when the a/c is off also. and the belt that is squeeling is in the front lower passenger side corner of the engine. (I don't know exactly where the a/c compressor is, so I'm not sure if this would be that belt.) But I can also get it to squeek when the truck is off, and I just push on the belt a little bit. Granted, it's not as bad as when the truck is on, but it does still squeek. If that is the a/c belt, would i have to replace the a/c compressor, or how would I fix that problem? Thanks Slade901 07-27-2006, 12:30 AM take the serpentine belt off and try to spin the ac compressor pulley. You should find out exactly if the ac compressor pulley is hard to turn if it's partially seized. The serpentine belt should route on alternator pulley, power steering pulley, water pump pulley, harmonic balancer pulley (lowest), and ac compressor pulley. jscheuffele 07-27-2006, 04:59 PM Thanks for your help. Ok, I took of the surpentine belt and spun the a/c compressor by hand, and it moved pretty easily.:banghead: Anything else it could be? Or do you know where the low idle adjustment screw is, for a temporary fix for this? Thanks. jscheuffele 07-28-2006, 12:49 PM Update: I noticed that when I turn the wheel really sharp, as if to park, it will sometimes die, with the A/C off. So, the strain from the Power Steering pump will cause it to die as well as turning on the a/c... does this ring a bell to anyone as a specific problem? Thanks! Automotive Network, Inc., Copyright ©2012
