Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Xterra > The School of Hard Rocks
The School of Hard Rocks Trail carnage and appeals for repair advice.
Old 07-13-2006, 03:03 AM   #1
bighead
bighead Normal reputation
Blinkers inop
Greetings... I have a 2001 X, manual, 6cyl. .. When I use the blinker...reguardless if i turn it left or right... the blinker will flash a few times and then shut off... If I re-engage the blinker.. the same thing will happen. Any ideas?
Thanks...
bighead is offline   Reply With Quote
Old 07-13-2006, 04:28 PM   #2
OffroadX
OffroadX Normal reputation
Send a message via AIM to OffroadX
Re: Blinkers inop
First of all, bless you for posting in the correct section!
Good luck,
Brent
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 07-14-2006, 01:55 AM   #3
bighead
Re: Blinkers inop
The plot thickens... The flashers work... the blinkers work... but sometimes they stop on their own..also, the "speed" of the relay varies. Sometimes it will click fast and then slow down and then speed up... It baffles me...
Thanks again...
Old 07-14-2006, 07:14 PM   #4
OffroadX
Re: Blinkers inop
Sounds like a flaky flasher unit.
Old 07-16-2006, 04:11 PM   #5
bighead
Re: Blinkers inop
i was thinking the same thing... next question... where is it located?
Old 07-18-2006, 07:14 AM   #6
OffroadX
Re: Blinkers inop
Not entirely certain, somewhere behind/below the dash.
Old 07-18-2006, 11:30 PM   #7
bighead
Re: Blinkers inop
Okay I got it fixed. The dealer wanted $56.00 for the part. I went to Napa and got it for $15. I used part number EP-34. The only difference was the Napa part didn't have the fancy molding on it... But, no worries.. You can take the relay portion out of the Napa part and use the Nissan molding to put it back in correctly.
I've attached a few images that show where the flasher is located and how to remove it from the truck.
Thanks a lot for the assistance....
Sorry for the small images.... it's all they would allow..... if you want to see the originals, send me a PM
Old 07-19-2006, 07:38 PM   #8
Schludwiller
XTerra Guy
Schludwiller's Avatar
Schludwiller Normal reputation
Re: Blinkers inop
Glad you got it fixed. If you don't mind, could you put a post in here for other people searching?
http://www.automotiveforums.com/vbul...play.php?f=865
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 08-03-2006, 08:20 PM   #9
Yusuf.jr
Yusuf.jr Normal reputation
Re: Blinkers inop
Do you have to remove any panels, to get access to the flasher unit? I tried crawling under my steering wheel, but I can only get one hand on it....Hard to see with out breaking anything.
Yusuf.jr is offline   Reply With Quote
Old 08-27-2006, 04:57 PM   #10
desmos2r1k
desmos2r1k Normal reputation
Re: Blinkers inop
For the Life of me I can't seem to find it... I bought the NAPA replacement unit, and have pulled most of the dash.... am I missing something?
desmos2r1k is offline   Reply With Quote
Bookmarks
Google
Web AF
