Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Ranger/Courier
Old 08-10-2002, 01:34 PM   #1
cromag_rickman
cromag_rickman
Question Engine Swap possible?
I have an 89 Ford Ranger, 2WD, standard, 4 cyl.
I found a Ford Topaz with a 6 cyl engine for a decent price, I want to switch out the engines...is this possible? Will all the pieces match up and such? Will I have mounting problems?
Appreciate input,
Cromag
ps. Please email at my address
cromag_rickman is offline   Reply With Quote
Old 08-11-2002, 05:59 PM   #2
Autoenthuser
Autoenthuser
Send a message via AIM to Autoenthuser
Find another ranger of the same model with a 2.9L V6, that should fit perfectly, i don't know about the engine in the Topaz. You could also go with a 5.0.
Autoenthuser is offline   Reply With Quote
Old 08-14-2002, 10:57 PM   #3
Ranger_X
Ranger_X's Avatar
Ranger_X
well, topaz is a fwd vehicle, so i don't know how it'll mount up. And I know the tranny in the topaz is not the same as your ranger's so probably not. Best bet is to put in a 4.0 or 5.0, 4.0 being the easiest.
-Will-
96 M56 Volvo 855 Turbo
87 A555 Chrysler Daytona Shelby Z
Ranger_X is offline   Reply With Quote
Old 09-01-2002, 01:37 PM   #4
Proxses
Proxses
A 5.0 is way too much fun to even consider anything else, in my opinion.
There are companies that sell everything for the 5.0 swap.
Plus with a 5.0, the list of mods is endless.
Proxses is offline   Reply With Quote
Old 09-26-2002, 03:09 PM   #5
nstag8
nstag8
V8 it !!!!!!!!!!!
My first truck was an 83 Ranger with a built 302 in it .My brother and I did all the work.It was great.It's a little more work then putting another 4 banger or a 6 popper in it, but alot more fun.
nstag8 is offline   Reply With Quote
Old 10-20-2002, 12:07 PM   #6
FireTeg93
FireTeg93
Send a message via AIM to FireTeg93
But what about....
Yes, I got rid of my Integra...and happened to befall a 4-cyl Ranger. It is possible to swap a FWD to a RWD...you need custom engine mounts and a tranny that will bolt up. Now...here is my question along the same lines. I have a 1989 Taurus SHO 3.0L DOHC V6 :finger: in my storage center. I've already got the intake reversed with appropriate spacers (runners were symmetrical), crankcase vent reversed, exhaust downpipes switched, two sensor wires lengthened, all the lines lengthened or shortened as needed, rear water outlet sectioned and run to the front, and I have a Lincoln Towncar 82mm throttle body swaped onto this engine. I have already made measurements and have found that I will lose my air conditioning, but the mount locations are the exact same as the Ranger 2.9L. I already have a Ranger 2.9L 5-spd tranny that bolts right up with no modification, a better driveshaft, and an 8.8" rear. My only problem now is finding out what kind of mounts I will need to use. Should I custom make mounts out of the Taurus top piece with another bottom piece...or should I go solid-type...ore are there a set of mounts that will properly work? What will fit it correctly?
"Whoever acquires knowledge and does not practice it resembles he who plows his land and leaves it unsown"
FireTeg93 is offline   Reply With Quote
Old 11-03-2002, 11:37 PM   #7
99silverGT
99silverGT
Send a message via Yahoo to 99silverGT
first of all if u are going to swap to a v6 u need to go with either a 3.0 or a 4.0 a 2.9 is too old. dont mess with the topaz. if u go with the 3.0 u can retain the 4cyl tranny. the 4.0 has a different tranny. the starter is on the other side. the tranny from the 2.9 will also fit the 4.0 but 3.0 and 4cyl are the same. the internals are the same on the tranny but dont open it up and try to switch one. been there done that. it will work but is a lot of trouble.
99silverGT is offline   Reply With Quote
Old 11-05-2002, 01:07 PM   #8
83ranger
83ranger
Send a message via AIM to 83ranger
Thumbs up
i found a 67 ford galaxy 500 4 door it had a 390 in it so i put a hot battery and some gas and i tfired right up so i bought the car for 400 and took it home and took the engine and then i am putting it in my ford ranger but my problem is that i dont know if i should rebuild the engine before i put it in or just put it in and drive it . its a strong engine it has lots of compression i went to turn it with a rachet and a extension and it snapped my craftsmen extension. i need to let the carborator soke in gas but i just dont know if i want to wast that money rebuiling.:
83ranger is offline   Reply With Quote
Old 10-07-2003, 02:56 PM   #9
blutruk
blutruk Normal reputation
Re: Engine Swap possible?
and how to do that?? do u need to change wiring harness or rear end??
blutruk is offline   Reply With Quote
Bookmarks
Google
Web AF
