Relay Locations on a 1998 taurusjtquad 07-12-2006, 03:57 PM Where is the Solid State Relay and EAIR Moniter? Im trying to narrow down the Code 1413 Problem. Thanks - JT shorod 07-13-2006, 11:37 PM Where is the Solid State Relay and EAIR Moniter? Im trying to narrow down the Code 1413 Problem. Thanks - JT I replied to your private message with the troubleshooting procedure and the location diagram for the EAIR relay. I made the assumption you have the 3.0L 12V engine since you didn't state which engine. The EAIR monitor is the entire circuit, so I'm not sure what you're lookign for there. -Rod jtquad 07-14-2006, 08:40 AM Thanks so much, problem found. Burnt wire on connector near air pump. Previous owner had a 50A fuse in there and must have fried the wire because of it. Thanks for all the help I appreciate it - JT shorod 07-14-2006, 02:18 PM Good job, and thank you for the follow up. -Rod Automotive Network, Inc., Copyright ©2012
