Re: Help 92 Astro Awd
The 4.3L engine is very sensitive to the brand of spark plugs that are used in it. AC Delco double platinum plugs are recommended by the manufacturer, and you will get the best performance when using them. There is something about the crossover with other plug manufacturers and they can't seem to get it right. As a result, the engine runs poorly. I realize it's a lot of work and money to replace them, but the engine will run better using the AC plugs, guaranteed. When the check engine light comes on, what code(s) is it storing? Auto Zone and Advance Auto will check it at no charge for you. The Idle Air Controller, (IAC) could be causing the stalling problem. The IAC is a computer output and may or may not cause the check engine light to come on, might be worth a try. Another possibility is that the EGR valve may have carbon in it not allowing the pintle to close completely. The valve can be removed and cleaned out very easily. Hope this helps.
